Hello Guest it is October 20, 2026, 02:51:16 PM
Author Topic: 4th axis set up on B axis query  (Read 9520 times)
« on: November 26, 2018, 08:56:02 AM »
I currently have mach3 set up using 4 motors X,Y, Z and slave the Y using the A axis. I want to include a 4th axis i.e. rotary positioner . I guess I have two questions about that.
Q1: Can I use the B axis as an alternative to A axis
Q2: If I reconfigured the controller wiring to run both Y axis motors off the same pins, which would then free up the A axis would that be an advantage? As both Y axis motors currently home separately I find this useful to square the table but could be persuaded to switch to dual Y.
  •  9,374 9,374
Re: 4th axis set up on B axis query
« Reply #1 on: November 26, 2018, 09:20:35 AM »
Within Mach3 you can configure the B axis to be slaved with your Y axis - thus freeing up your A axis for rotary working.
It is not recommended to connect two axis (motor drivers) to the same pin.
« Reply #2 on: November 26, 2018, 03:15:11 PM »
Thanks 4 reply. I set up the B axis to be slaved with the Y axis. I was just trying to keep B free for when I build a B/A head.
Just out of interest why is it not recommended to connect two axis (motor drivers) to the same pin?
Offline TPS
  •  2,627 2,627
« Reply #3 on: November 26, 2018, 03:27:47 PM »
why you do not have a chance to square the axis by homing
