Mach Discussion => General Mach Discussion => Topic started by: marbles on November 26, 2018, 09:56:02 AM
I currently have mach3 set up using 4 motors X,Y, Z and slave the Y using the A axis. I want to include a 4th axis i.e. rotary positioner . I guess I have two questions about that.
Q1: Can I use the B axis as an alternative to A axis
Q2: If I reconfigured the controller wiring to run both Y axis motors off the same pins, which would then free up the A axis would that be an advantage? As both Y axis motors currently home separately I find this useful to square the table but could be persuaded to switch to dual Y.
Within Mach3 you can configure the B axis to be slaved with your Y axis - thus freeing up your A axis for rotary working.
It is not recommended to connect two axis (motor drivers) to the same pin.
Thanks 4 reply. I set up the B axis to be slaved with the Y axis. I was just trying to keep B free for when I build a B/A head.
Just out of interest why is it not recommended to connect two axis (motor drivers) to the same pin?
why you do not have a chance to square the axis by homing
