Hello Guest it is November 11, 2026, 11:05:22 PM
Author Topic: Z plunging after next cut  (Read 21630 times)
« on: November 23, 2018, 11:06:13 PM »
New to mach3 i have a 4x8 router table. The first cut cycle cuts perfect depth and when the machine cycles to (next cut same tool) the g code has the same Z movement but it plunges into the stock over an inch and breaks the bit. I use bobcad to generate g codes and an industrial cnc router table. I do have a uc100 controller on windows 10. Any tips would be great!
  •  9,377 9,377
Re: Z plunging after next cut
« Reply #1 on: November 24, 2018, 12:50:34 AM »
Sounds like you Z axis could be missing steps on the rapid upward (+Z) movement.
Try halving the Z axis Velocity and Acceleration settings in motor tuning and save the changes. If this makes any difference then experiment with your Z axis motor tuning settings until it performs correctly.
