Hello Guest it is November 23, 2026, 02:52:10 AM
Author Topic: Go to Zero not working Mach 3  (Read 8649 times)
« on: November 13, 2018, 10:03:11 AM »
Hi all,
Having a problem with the Go To Zero button in Mach3.
It worked up until about 2 weeks ago.
Now when I hit it, the Z-axis lifts until it hits the limit switch, then triggers and stops.  It never homes X or Y.
I have changed nothing and no updates have been done.
Any ideas?
Mike
Re: Go to Zero not working Mach 3
« Reply #1 on: November 13, 2018, 10:36:53 AM »
Check your Safe Z settings in Config > Safe Z.
« Reply #2 on: November 13, 2018, 07:54:12 PM »
Was set to Machine Coordinates instead of Work Coordinates!  Good call!  Changed it to Work Coordinates and its all good.
Thanks!
Mike
« Reply #3 on: November 14, 2018, 06:12:31 AM »
It's better to be in Machine Coordinates, provided you have a Z axis home switch, and use it.
