Hello Guest it is November 23, 2026, 03:42:37 AM
Author Topic: port 2 pin 2-9 as inputs  (Read 7938 times)
Offline fast89
  •  167 167
« on: November 11, 2018, 01:31:56 PM »
First off, i cannot search, i keep getting an error:
2: pspell_new(): PSPELL couldn't open the dictionary. reason: No word lists can be found for the language "en".
File: /var/www/vhosts/machsupport.com/forum.machsupport.com/forum/Sources/Search.php
Line: 700
Now to my real problem. I can't get mach to see port 2 pin 2-9 as inputs. I have it checked on ports and pins page. Address is right because outputs work. My pci parallel card is the same as i have in other machines and is capable of ecp, epp, and spp modes. Windows 7 will only show it as ecp LPT port  in device manager.  I thought this was the problem but my other windows 7 machines show the same thing. In bios, i cannot set it for epp only, my only choice is ecp/epp mode. I guess at this point, i need to probe the cable and make sure the signal is getting all the way back to the pci card. Pretty sure it is though.
« Last Edit: November 11, 2018, 01:37:32 PM by fast89 »
  •  9,378 9,378
Re: port 2 pin 2-9 as inputs
« Reply #1 on: November 12, 2018, 12:47:20 AM »
The Search function is currently off-line but should return once the webmaster finds and replaces the missing / moved file.  :)
As far as the Mach3 Parallel Port is concerned Pins 1-9 are always Outputs - they cannot be changed to Inputs.
Some, if not all, External Motion Controllers (such as the Warp9 ESS) will allow Pins 1-9 of Port 2 to be configured as Inputs so if that's what you need then consider changing from the Parallel Port to a Motion Controller.
Offline fast89
  •  167 167
« Reply #2 on: November 12, 2018, 11:35:59 AM »
Wow....i'm an idiot. I've got 4 parallel port machines and i knew this. Just happens that i've been messing with a smooth stepper for a few months on one machine.
