Hello Guest it is November 13, 2026, 10:02:39 AM
Author Topic: G and M code for beginners  (Read 10985 times)
Offline Klaus
  •  42 42
« on: October 20, 2018, 05:12:39 AM »
Hi all
I'm still very new to this just waiting for my machine to arrive.
While I have been waiting I have tried to learn Mach3 and when I open one of the Test G-code files like the Roadrunner.tap, some of the first lines is not G-codes and not M-codes and I can't find any documentation for this code so that's why I am asking here. This is the lines:
F60.000000
G0 X0.000000 Y0.000000 Z0.200000
M3
S60.000000
G43H5
As you can see there are both F and S codes, what do they do?  and the H5 Code in the last line?
  •  9,377 9,377
Re: G and M code for beginners
« Reply #1 on: October 20, 2018, 05:42:25 AM »
Hi Klaus,
Unfortunately the Mach documentation is spread far and wide.
The main Mach3 screen has G-Code and M-Code buttons – clicking these will give you a brief description of the various functions.
A slightly more detailed explanation of these Codes can be found in Section 10 of the Mach2 manual;   http://www.machsupport.com/wp-content/uploads/2013/02/Mach2Mill_6.11.pdf
I have also linked an excellent tutorial here;   http://www.machsupport.com/forum/index.php/topic,38540.0.html
Hope this helps.
Offline Klaus
  •  42 42
« Reply #2 on: October 20, 2018, 08:06:21 PM »
Hi Tweakie and thanks for your answer.
Yes it is a great link with a lot of useful information but it doesn't answer my question  ???
Klaus
  •  9,377 9,377
« Reply #3 on: October 21, 2018, 12:42:08 AM »
I don't think you are reading the information in the links I have provided  ;D
Section 10 of the manual describes the F and S commands and if you look up G43 it describes the H parameter and it's function.
Was there any other question ?
« Last Edit: October 21, 2018, 01:29:27 AM by Tweakie.CNC »
Offline Klaus
  •  42 42
« Reply #4 on: October 21, 2018, 03:46:41 AM »
Yeah sorry, I was looking at your second link, The CNC Cookbook. I found it now thanks so much.
« Last Edit: October 21, 2018, 03:53:41 AM by Klaus »
  •  9,377 9,377
« Reply #5 on: October 21, 2018, 03:55:17 AM »
