Hello Guest it is October 20, 2026, 07:00:53 PM
Author Topic: Drivers  (Read 9715 times)
Drivers
« on: August 02, 2007, 03:18:13 AM »
Does anyone have a listing for a bi-level driver that'll work with Mach3?
 I understand that cards of this design are more stable and aren't effected by the interference issues that affect chopper style driver cards. I need a driver that can be hooked up to 8 wire Nema 34 steppers that if wired in parallel require 3.05 volts per phase.
Re: Drivers
« Reply #1 on: August 02, 2007, 06:07:26 AM »
You will need to do about 30V (name plate X10).. Have a look on the web at Gecko drive or the drives from Keling.
thanks
Brian
www.newfangledsolutions.com
www.machsupport.com
