Hello Guest it is October 24, 2026, 05:25:23 PM
Author Topic: Max velocity for Nema 24 motors  (Read 9317 times)
« on: September 27, 2018, 01:55:59 PM »
Hey guys,
Im setting up my motors in mach 4,  Ive got a routakit  HD with a stdr-4c controller with nema 24 motors. Im at 2000 units per minute (x axis) and it seems like its still running great.  I don't know what a reasonable number would be.  How much faster can/ should I go????
Re: Max velocity for Nema 24 motors
« Reply #1 on: September 27, 2018, 03:42:59 PM »
I think Craig has given someone a good "formula" for stepper velocity before, somewhere on this forum.
But here at the shop, I keep bumping the velocity up a little at a time until the motor stalls; once I find where it is as fast as possible without stalling, I back off about 20%.  Works pretty good for us.
Chad Byrd
« Reply #2 on: September 27, 2018, 04:44:51 PM »
Thanks! That's the same method listed in the Mach manual but Ive never experienced a stall.  Is it hard to miss?
« Reply #3 on: September 27, 2018, 04:48:38 PM »
You'll know when it stalls.
« Reply #4 on: September 27, 2018, 07:26:07 PM »
Gerry is correct.  lol  You will know when it stalls.  The table will stop moving and it'll make a funny noise.
Chad Byrd
« Reply #5 on: September 28, 2018, 09:42:24 AM »
Thanks guys!   On my X axis im so fast now its uncomfortable.  Is there any reason I cant run at a lower velocity?  I assume you want any velocity that is satisfactory as long as its lower than that 20% of max velocity?
« Reply #6 on: September 28, 2018, 09:48:44 AM »
That's entirely up to you.  I have a Carbide Knife Grinder in the shop that can move at 200+ IPM but I've got it set to 40-50 IPM because I don't want the operators to crash the machine because they aren't paying attention.
Chad Byrd
