Hello Guest it is October 29, 2026, 12:13:31 AM
Author Topic: Denford Lathe  (Read 8484 times)
Denford Lathe
« on: September 27, 2018, 08:34:58 AM »
 I just purchased a Denford Mirac from a tech. school auction. It's complete with the control box, IE power supply, drives, etc. I've been waiting on a reply about Denford's control software for a few days now which leads me to my question. Can I just assign which pins do what and assign high or low using Mach3 to get it to move, or would I need to do a rebuild on break-out boards and start from scratch?
Re: Denford Lathe
« Reply #1 on: September 28, 2018, 07:56:55 AM »
After a bit more investigating I'm not sure it's a simple procedure or possible. The Denford control box uses a DB9 connector and a null modem cable, but Mach seems to rely on a DB25. I'm not sure they're enough pins available.
Re: Denford Lathe
« Reply #2 on: September 28, 2018, 04:41:36 PM »
The 9 pin is serial and 25 pin is parallel. So Denford had a motion control board that is likely completely incompatible with Mach 3. You’ll need a Mach 3 or 4 compatible breakout board or motion controller. If you going to rewire use a motion control board with USB or Ethernet like a smoothstepper or other.
Re: Denford Lathe
« Reply #3 on: September 28, 2018, 05:23:50 PM »
Makes sense, thanks for the reply.
