Hello Guest it is November 13, 2026, 08:00:12 PM
Author Topic: Mach3 MDI line issue  (Read 8198 times)
« on: September 26, 2018, 08:07:18 AM »
Hello all,
 I just installed Geckodrive G540. Unfortunately the xml file crashes my computer so I am manually going through all the settings. I have almost everything all set however the MDI line isn't working correctly. If I type in G0X1.5 the table doesn't move to x=1.5 but it does move 1.5". In other words if the x is at 2.000" and I type G0X1.5 the table will move to x=3.5.
Can you please let me know which setting I should be looking for?
Re: Mach3 MDI line issue
« Reply #1 on: September 26, 2018, 09:15:17 AM »
sounds like your in incremental mode.
Confirm that you are in absolute distance mode and IJ Incremental mode.
Next read up on G90 and G91 modes. MDI a G90 to be sure.
« Reply #2 on: September 26, 2018, 09:23:48 AM »
That was it,
Thanks Craig
