Hello Guest it is November 13, 2026, 08:09:32 PM
Author Topic: What files are needed?  (Read 10522 times)
Offline Klaus
  •  42 42
« on: September 21, 2018, 05:25:40 AM »
I have bought a machine from China which comes with Mach3. Yes I know I have said Mach4 but I have changed my mind  ;D
I have asked the company to send me the Mach3 profile they have used to test the machine.
So is it only one file like an ini. file or are there more?
Klaus
Re: What files are needed?
« Reply #1 on: September 21, 2018, 05:44:09 AM »
It's just a single .xml file
Offline Klaus
  •  42 42
« Reply #2 on: September 21, 2018, 05:47:05 AM »
Great thanks Gerry.
Offline Klaus
  •  42 42
« Reply #3 on: September 22, 2018, 06:48:07 AM »
Update
I can see now that if I only copy the XML file I won't get the macros with me.
Mach 3 makes a new Macro folder for each profile.
« Reply #4 on: September 22, 2018, 07:05:32 AM »
If you have custom Macros, Brains, Plugins, and Screens, then you need to copy those as well, plus the images for the screen in the BMP folder.
But all of your settings are in the .xml file.
You can copy the entire Mach3 folder, then, on a new PC, run the installer, and when it's finished, copy your old folder right over it.
