Hello Guest it is November 22, 2026, 05:28:42 PM
Author Topic: Analog joystick control...  (Read 12737 times)
« on: July 31, 2007, 01:11:55 PM »
I have the plugins for the usb joystick control,
both downloaded from the website.
what is the difference between the 2?
How does the incremental nature of a dynamic joystick control Mach jiogging If it goes through this keygrabber thing (isnt keygrabber basically a software version of ipac, as in keystroke emulation), im missing something here. I have some good sturdy industrial control joysticks (0-5volt positioning) I have an analog to usb coverter (Maplin Electronics in UK) that should plug and play so PC thinks its normal USB joystick
(http://www.maplin.co.uk/Module.aspx?ModuleNo=23256&C=Maplin&U=SearchTop&T=ANALOG%20JOYSTICK&doy=31m7
and i have mach3...
could someone shed a little light on my darkness...
benergy
Re: Analog joystick control...
« Reply #1 on: July 31, 2007, 01:27:38 PM »
I don't know if this will help you or not, but this is a thread about a Game pad I know works very well. Might help some, I hope it does.
http://www.artsoftcontrols.com/forum/index.php?topic=1391.0
« Reply #2 on: July 31, 2007, 01:42:34 PM »
Yea, I saw that, im running into similar probs. I think ill keep trying a bit longer then just get a ipac and settle for on-off joystick control...
« Reply #3 on: July 31, 2007, 01:52:00 PM »
I can help explain a little about Keygrabber if it will help, I'm not exactly sure what you want or need. I have sent you a personal message.
