Mach Discussion => General Mach Discussion => Topic started by: benergybenergy on July 31, 2007, 02:11:55 PM
Title: Analog joystick control...
Post by: benergybenergy on July 31, 2007, 02:11:55 PM
I have the plugins for the usb joystick control,
both downloaded from the website.
what is the difference between the 2?
How does the incremental nature of a dynamic joystick control Mach jiogging If it goes through this keygrabber thing (isnt keygrabber basically a software version of ipac, as in keystroke emulation), im missing something here. I have some good sturdy industrial control joysticks (0-5volt positioning) I have an analog to usb coverter (Maplin Electronics in UK) that should plug and play so PC thinks its normal USB joystick
(http://www.maplin.co.uk/Module.aspx?ModuleNo=23256&C=Maplin&U=SearchTop&T=ANALOG%20JOYSTICK&doy=31m7
and i have mach3...
could someone shed a little light on my darkness...
benergy
Title: Re: Analog joystick control...
Post by: Chaoticone on July 31, 2007, 02:27:38 PM
I don't know if this will help you or not, but this is a thread about a Game pad I know works very well. Might help some, I hope it does.
http://www.artsoftcontrols.com/forum/index.php?topic=1391.0
Post by: benergybenergy on July 31, 2007, 02:42:34 PM
Yea, I saw that, im running into similar probs. I think ill keep trying a bit longer then just get a ipac and settle for on-off joystick control...
Post by: Chaoticone on July 31, 2007, 02:52:00 PM
I can help explain a little about Keygrabber if it will help, I'm not exactly sure what you want or need. I have sent you a personal message.
