Hello Guest it is October 14, 2026, 04:30:36 AM
Author Topic: Novamill  (Read 46891 times)
Novamill
« on: July 30, 2007, 06:02:18 PM »
Just finished the control box on my Denford Novamill, it is 6 x 8 x 10 ins. My advice is to use a box at least twice the size you think you will need!!!
List of contents:-
3 Routout(UK) 2.5 amp stepper drivers.
CNC4PC C11G BOB.
24V 6Amp Power supply.
5V 2.5Amp Power supply.
Spindle motor Contactor.
E-stop relay.
Novolt release starter.
Big fan and filter.
The front panel was engraved with a 1.0 mm cutter using the Mach Write wizard.
Mounted on the back is the SMC-00 DC spindle motor controller from www.beel.ca and an EMC Filter.
The numbers, which are 5mm high, were created in DesignCad using a vector font, exported as a DXF, then imported into Lazycam. I used a small pneumatic impact engraver resiliently mounted, to mark on the 45mm dia stainless steel tube.  DesignCad has a plug-in, ContourCam, which I have yet to play with.
Still learning but the curve IS getting less steep.
Ian Ralston
Re: Novamill
« Reply #1 on: July 30, 2007, 06:15:15 PM »
Sorry, the attachments didn't attach!
Try again.
Ian Ralston
Re: Novamill
« Reply #2 on: August 02, 2007, 03:28:30 PM »
Ian
 box looks good, what did you engrave it on?
Edit
 thought I better elaborate, what I mean is what material is it cut into?
Re: Novamill
« Reply #3 on: August 02, 2007, 04:56:15 PM »
Hood,
The engraving laminate was from  http://www.techsoftuk.co.uk the code was TAP-F5 white on black. They are a distributor for Rowmark.
Ian
Re: Novamill
« Reply #4 on: August 02, 2007, 06:41:29 PM »
Yeap, I'll have to agree with Hood. It looks nice. :)
Re: Novamill
« Reply #5 on: August 04, 2007, 10:58:11 AM »
Thanks Ian, now if only they sold similar stuff with Black  on the face and Aluminium underneath I would be delighted. :D
Re: Novamill
« Reply #6 on: August 04, 2007, 11:38:57 AM »
Hood,
Try here :-
http://www.mastergrave.co.uk/catalogue/detail.php?product_ID=1627&product_Category_ID=127
Quite how you get good lettering with this, I can't advise.
Ian
Re: Novamill
« Reply #7 on: August 04, 2007, 11:49:12 AM »
Thanks Ian,
 Looks good but maybe on the thin side for what I want. Might be an idea to get some 5mm Alu anodised and see how things work out, I think the local platers may be able to do it for me.
Re: Novamill
« Reply #8 on: November 27, 2011, 10:39:41 AM »
Hi Ian,
Could I ask a question?  I see you're using 2.5A stepper drivers (Routout), I've just got a Novamill minus its electronics so I'm adapting it to Mach3 with new drivers.  I see that the Z axis drive seems to use a NEMA 38 motor, is 2.5A enough to drive this please?
Cheers,
John.
Re: Novamill
« Reply #9 on: November 28, 2011, 08:00:41 AM »
John,
All three axes were Nema 23, so I didn't have any problems. If your steppers are eight lead, you might be able to seriies connect them for a lower drive current.
Ian
