Hello Guest it is November 13, 2026, 01:02:25 PM
Author Topic: no movement on display  (Read 10143 times)
« on: September 09, 2018, 09:03:41 AM »
Loaded Mach3 and post gcod or wizard and the code runs through but machine x,y, and z show no movement.
Re: no movement on display
« Reply #1 on: September 09, 2018, 11:00:29 AM »
what PC are you using?
What OS is loaded?
Are you using a parallel port?
If so post an image of DriverTest.exe results.
What breakout board and/or motion controller are you using?
« Reply #2 on: September 10, 2018, 08:00:18 AM »
Dell OptiPlex 760 using windows XP. Parallel port being used. The driver test showed "excellent" and the pulse rate was very steady at about 27,000.  I have yet to hook up my machine, but am not seeing any motion on the display DRO's. I remember from years ago that the display showed motion and the display actually showed the tool movement. I am not getting that now. Thanks for your reply.
Offline ZASto
  •  434 434
« Reply #3 on: September 10, 2018, 09:11:28 AM »
Have you enabled your motors in Ports & Pins?
My personality is who I am.
« Reply #4 on: September 10, 2018, 02:15:20 PM »
without motors being assigned, even if not connected then Mach will not display an axis movement.
« Reply #5 on: September 11, 2018, 04:20:47 PM »
OK  I will go through the entire setup process and see if that makes it work....fingers crossed.
