Hello
Guest
it is
November 13, 2026, 09:48:27 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
"RUN FROM HERE" Z- Axis goes to Limit switch???????
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: "RUN FROM HERE" Z- Axis goes to Limit switch??????? (Read 10615 times)
barefootboy4
4
on:
September 04, 2018, 06:41:54 PM »
Hello everyone,
So I have been running Mach 3 for about 8 years now and love it. I do have an issue with the "RUN FROM HERE" command. If for some reason I need to stop a cutting program or maybe catch a false limit trip I normally use the RFH command. When I hit the "CYCLE START" the "Z" will go up to MAX travel and hit the limit switch. After posting this question on CNCzone.com everyone feels this is caused by Mach 3 and not my CAM G-code generator which is RhinoCAM. They have pointed me towards Config/Safe Z. So my question is can someone explain in detail what the settings should be in Config/Safe Z to prevent this issue from happening or am I looking in the wrong place?
Thanks in advance
Steve
Logged
ZASto
434
Re: "RUN FROM HERE" Z- Axis goes to Limit switch???????
Reply #1 on:
September 05, 2018, 07:44:07 AM »
Set your SafeZ just below Z limit switch.
Logged
My personality is who I am.
barefootboy4
4
Reply #2 on:
September 05, 2018, 11:45:56 AM »
Thanks for the quick reply. I assume I set using Machine Coordinates?
Steve in Maine
Logged
ZASto
434
Reply #3 on:
September 05, 2018, 12:00:43 PM »
Safe Z iz im Machine Coordinates.
When you home your machine, Z zero is just a fraction below Z limit switch (by the ammount of backing off)
Logged
barefootboy4
4
Reply #4 on:
September 05, 2018, 12:36:39 PM »
Thanks for the reply1
Just reconfigured my machine using SAFE Z and it works.
Thanks again for the help.
Steve in Maine
Logged
ZASto
434
Reply #5 on:
September 05, 2018, 02:35:45 PM »
You're welcome
Logged
Print
Pages:
1
Go Up
« previous
next »
