Hello
Guest
it is
November 13, 2026, 01:37:05 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
x, y and z keyboard commands
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: x, y and z keyboard commands (Read 11980 times)
MACHSHOP
5
on:
August 27, 2018, 04:35:02 PM »
on our mach3 program the x, y and z keyboard commands do not work correctly. how can we fix this?
joeaverage
7,663
Re: x, y and z keyboard commands
Reply #1 on:
August 27, 2018, 04:43:00 PM »
you could start by telling us about your machine and PC.
Are you using a parallel port for instance?
ger21
6,295
Reply #2 on:
August 27, 2018, 07:03:57 PM »
Define "not correctly". If they work, but move the wrong axis or the wrong direction, than it's quite possible that your machine is setup incorrectly.
If they don't work at all, try Config > Hotkeys.
MACHSHOP
5
Reply #3 on:
August 28, 2018, 08:55:30 AM »
it's mach3 2.0, vortech router 3axis and think the pc is vista that came with the machine when we got it brand new. our x axis key is moving z axis. the z axis keys move on the screen but not the motor, x axis keys move on the screen but not the motor. same as with y axis. thank you.
ger21
6,295
Reply #4 on:
August 28, 2018, 10:49:04 AM »
So some of the motors don't work at all, even if you run g-code?
If the machine was working, it sounds like your installation has become corrupted.
MACHSHOP
5
Reply #5 on:
August 28, 2018, 11:55:31 AM »
we have not tryed g code yet we will try. and the pc is xp not vista. and when we turn on max CL z works on x keys and y axis works right x axis wont work. with max CL off all axis move on screen on the right keys but no motor movement. thank's for your time and help on this matter.
MACHSHOP
5
Reply #6 on:
August 28, 2018, 01:18:06 PM »
we ran g code program the axis moved on screen also too path worked, no motor movement spindle did not come on. ran thur whole program and rewind.
Print
Pages:
1
Go Up
« previous
next »
