Hello Guest it is October 11, 2026, 07:34:36 PM
Author Topic: Spindle On and Off- Please help  (Read 17718 times)
« on: July 24, 2018, 10:29:47 AM »
Good morning, any help on this issue, is greatly appreciated.
Runing Mach3 on 4x8 CNC, steppers and spindle.
I can turn on and off the spindle from Mach 3.
When I load a program, the spindle starts and then when the Gcode start running, the spindle shuts off and right after the program finishes,
the spindle starts back on.
I also see the yellow abnormal condition on, but that refers to the axis...
What I have been doing is that as soon as I see the spindle CW F5 button start flashing , I can click on it again to start the spindle , finish the cut , and then
turning it off...
  •  9,374 9,374
Re: Spindle On and Off- Please help
« Reply #1 on: July 25, 2018, 12:59:57 AM »
turning it off...
The spindle should be running when the CW F5 button is flashing - is that the way you have it set-up ?
« Reply #2 on: July 25, 2018, 07:12:03 AM »
Hello, I appreciate your help very much.
Before I press the Cycle Start , the spindle is already running. When I start the program, the Spindle CW F5 is blinking , and the spindle stops. When the program ends, the Spindle CW F5 stops and the spindle starts again.
Let me know what are your thought please
Manny
  •  9,374 9,374
« Reply #3 on: July 25, 2018, 08:48:24 AM »
Sounds like you have your spindle control incorrectly wired - the spindle should not be running before Cycle Start is pressed.
You need to check your wiring connections.
« Reply #4 on: July 25, 2018, 08:56:04 AM »
When the machine is powered on, Mach3 is not up on the screen, the spindle is off. When I open up Mach3 , the spindle comes on and then the sequence I previously described. Does it have to do with the Pins on the BOB? Where to find the pins for the relay...
  •  9,374 9,374
« Reply #5 on: July 25, 2018, 09:06:17 AM »
I don't think this is the answer but try...
In Config / Ports & Pins / Spindle Setup - note the Output# used for Clockwise (M3).
In Config / Ports & Pins / Output Signals – for the Output# noted above, change the Active Low setting.
Offline TPS
  •  2,627 2,627
« Reply #6 on: July 26, 2018, 02:08:53 AM »
if you tell us witch BOB you are using, and what is cobbected on the BOB,
someone may be able to help.
