Hello
Guest
it is
November 13, 2026, 10:07:24 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Set Output when homing
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Set Output when homing (Read 10358 times)
Cos_phi
1
on:
July 10, 2018, 03:50:33 PM »
Hello!
I am new in this Forum.
I have build an 3 axis Portal milling with Mach3 Software and a Beckhoff PLC. The PLC is connected with all limit, reference and emergency switches and disable and enable the drives. My negative limit switch is also my reference switch. So the PLC has to know when the machine is homing. The easiest way would be to set an Output when the machine is homing.
Is there a way to realize this???
with best regs
cos_phi
BluePinnacle
307
Re: Set Output when homing
Reply #1 on:
July 11, 2018, 05:54:35 AM »
I had a similar question which could have a similar answer - I need an output to come on when the "Start cycle" LED is on, so that the output is high while a program is running, it's for a slideway oiler.
Print
Pages:
1
Go Up
« previous
next »
