Hello Guest it is November 13, 2026, 09:46:20 AM
Author Topic: Set Output when homing  (Read 10356 times)
« on: July 10, 2018, 03:50:33 PM »
Hello!
I am new in this Forum.
I have build an 3 axis Portal milling with Mach3 Software and a Beckhoff PLC. The PLC is connected with all limit, reference and emergency switches and disable and enable the drives. My negative limit switch is also my reference switch. So the PLC has to know when the machine is homing. The easiest way would be to set an Output when the machine is homing.
Is there a way to realize this???
with best regs :)
cos_phi
Re: Set Output when homing
« Reply #1 on: July 11, 2018, 05:54:35 AM »
I had a similar question which could have a similar answer - I need an output to come on when the "Start cycle" LED is on, so that the output is high while a program is running, it's for a slideway oiler.
