Hello Guest it is November 19, 2026, 11:53:57 AM
Author Topic: Update mach4 help  (Read 8124 times)
Update mach4 help
« on: June 16, 2018, 09:35:44 PM »
Ok,
I have updated my Mach4. Loader info came over and my controller but no setting as in pin port for controller and no motor setting. Its all blank. I saved the whole Mach4 folder before loading. Can I copy and past from there to my new updated Mach4 folder to get settings back.
Anthony l
Re: Update mach4 help
« Reply #1 on: June 16, 2018, 11:57:37 PM »
you need to have a uniquely named profile AND screenset or it will get overwritten when you update.
http://www.machsupport.com/forum/index.php/topic,37337.msg255420.html#msg255420
« Reply #2 on: June 17, 2018, 08:33:37 AM »
Thanks Craig,
My profile was g0704 and my screen was set to my mill. I had made a G0704 Screen but I guess somewhere down the line being a newbie it got changed to mymill. I guess all my setting was under screen my mill. I loaded the G0704 screen up but there's no setting. I pretty sure it was set to my mill. I have screen g0704 loaded now. Maybe all my setting will be saved under with Profile G0704 and Screen G0704.
  Craig,
A while back my load license file would not work. I went on the site and I some how got another one. Ii works but about once a month my Mach4 goes back to demo mode and I have to load it again. Is that normal. I have two Load Licence files. One that works and one that doesn't and both on the same PC.
Thanks Anthony L
« Reply #3 on: June 17, 2018, 01:43:07 PM »
what screen set is your ScreenG0704 based on?
What I suggest is in the  Mach4/Screens folder make a copy of a screenset you like, say wx4.set and call it awleaphartwx4.set say.
Then when you create a profile use it as the screenset. It wont get overwritten.
The licence file no longer works if the PCID changes. If you have reloaded the OS for instance.
« Reply #4 on: June 17, 2018, 02:14:47 PM »
Got it.
Thanks alot
