Hello Guest it is November 14, 2026, 05:43:55 PM
Poll
stuck my axis when load larg g-code 900.000 lines
g-code problem
0 (0%)
mach3 stuck
0 (0%)
Total Members Voted: 0
Author Topic: large g-code problem on mach3  (Read 11556 times)
« on: May 31, 2018, 06:02:28 AM »
hello .I have problem with mach3 when load large g-code 900.000 lines. Mach3 is begin slow and when i move axis loosing a lot of steps and stuck, in other smaller g-code files runs without problem , i use a full version on mach3 and i have pc windows7 with intel pentium4 3ghz , memory 3ghz  and graphic card  amd radeon r7 1ghz memory. How to solve the problem? (sorry for bad english) :)
  •  9,377 9,377
Re: large g-code problem on mach3
« Reply #1 on: May 31, 2018, 07:12:55 AM »
As a test try turning off the Toolpath Display (Diagnostics screen) - if your 900,000 line code then runs OK the problem is most likely with your graphics card.
« Reply #2 on: June 05, 2018, 12:09:31 PM »
thank you very much , the problem is from toolpath, now works fine. :D
  •  9,377 9,377
« Reply #3 on: June 06, 2018, 01:15:16 AM »
I am pleased you found the problem.
(Perhaps consider fitting a new Graphics card with 1GB or more memory).
« Reply #4 on: June 06, 2018, 10:01:10 AM »
He already has one, according to his first post.
