Hello Guest it is November 22, 2026, 07:26:03 AM
Author Topic: Mach for turning  (Read 13977 times)
Mach for turning
« on: July 20, 2007, 10:09:56 AM »
Hello Art and Brian
I have just downlaoded the latest Mach version and found that when the program is asked to go to Z it cut's the fresh turned part off on X and then returns to Z zero it didnt do this in the previous version's the program always rapid the Z to zero and then the X to zero can you guy's fix that ?
Rg's
Dennis
Offline zarzul
  •  233 233
  • Wyoming, USA
Re: Mach for turning
« Reply #1 on: July 20, 2007, 11:52:00 AM »
Dennis,
I use turn a lot and might be able to help.  What are you doing?  Are you running a wizard?  Which one?
Arnie
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #2 on: July 20, 2007, 01:07:31 PM »
Hi Dennis
Hears the Mach3R 2.01.000 lock-down exe, Z is working in it properly.
Thanks, Chip
« Last Edit: July 20, 2007, 01:10:02 PM by afn09556 »
« Reply #3 on: July 20, 2007, 08:04:41 PM »
Hello Arnie
Funny thing i was on the phone with Chip and we tried the turn wizzard just inputing random info and it worked, now it seams it's working maybe it was the vbersion i was using.
Are you using a cad/cam type program for your design if so which one?
Thanks Chip i have downlaoded the file 2.01.000 thanks again for all your help.
Rg's
Dennis
Offline zarzul
  •  233 233
  • Wyoming, USA
« Reply #4 on: July 21, 2007, 08:44:31 AM »
Dennis,
I am just using the wizards, they seem to work well for the simple stuff I do.
I made a couple of other ones to suppliment them, one to do an o-ring groove on an ID, some to turn a taper up to a flat face, a modified OD groove (that doesn't pull all the way out between pecks), one to do a o-ring groove on a faced end, and a partially done elipse (I struggled a lot with that one).
Arnie
« Reply #5 on: July 21, 2007, 01:01:50 PM »
Arnie
 Well at least your machining parts i am just struggling.
Dennis
« Reply #6 on: July 21, 2007, 01:02:42 PM »
Hey Chip
 I tried to install that version and for some reason it wouldn't go.
Dennis
