Hello Guest it is November 13, 2026, 11:51:05 AM
Author Topic: Mach3 stops approx every 10 min. / 10,000 lines of code  (Read 46376 times)
Re: Mach3 stops approx every 10 min. / 10,000 lines of code
« Reply #10 on: May 28, 2018, 08:13:21 PM »
Is there any type of message when it stops?
No - The only message next to reset is just "Press Reset...Emergency Mode Active" ... No error codes
So the reset button is flashing when it stops?
Sounds like you have noise triggering your estop input, or possibly a limit input?
« Reply #11 on: May 28, 2018, 11:37:57 PM »
is it possible that there is an overheat alarm which causes the Estop?
Would explain the approximate consistent fault AND the Estop.
« Reply #12 on: May 29, 2018, 06:50:07 AM »
If it was overheating, I doubt that he would be able to continue running after it stops?
Or if it did, I'd expect it to stop much sooner the next time?
« Reply #13 on: May 29, 2018, 04:17:52 PM »
Only the Chinese know how their thermal overload  works. suggest the user jumper it out and test.
Have a look at the schematic.
Offline Pythagoras
  •  93 93
  • a² + b² = c²
« Reply #14 on: June 03, 2018, 07:27:23 AM »
My 2 cents, noise on the Estop.
Also are you running the same gcode, and is it stopping at the same point in that code?
The Pythagorean theorem: The sum of the areas of the two squares on the legs (a and b) equals the area of the square on the hypotenuse (c).     a² + b² = c².
« Reply #15 on: February 16, 2020, 09:22:23 PM »
Any luck with this? I am having exactly the same issue. I have tried on different PCs with the he same result.
Thanks Marvin
« Reply #16 on: April 08, 2021, 11:56:48 AM »
Have the same issue. every 10 minuts stops without errors, anybody figure it out?
