Hello Guest it is November 17, 2026, 10:15:29 AM
Author Topic: ATC Spindle How to set them up?  (Read 18839 times)
« on: May 04, 2018, 01:19:27 AM »
Hi there
Could some one direct on how to set up an ATC Spindle, I am trying to Install a CC spindle, which is a copy of HSD,
Just a general Guide I need,
particularly on its sensors, do I need to address them in my ATC VB Scripts?
regards
jhonansaro
Offline TPS
  •  2,627 2,627
Re: ATC Spindle How to set them up?
« Reply #1 on: May 04, 2018, 01:28:06 AM »
if you have a Manual of your spindle we might have a Chance to help you.
« Reply #2 on: May 04, 2018, 01:37:06 AM »
Hi again TPS
I do not have a manual, it is very hard to get one I have searched the net, but no success.
As I said it is very similar to famous HSD brand, The spindle is installed by the person whom I purchased from, it was sort of easy, and it is working.
My question is very general, Basically what is the general procedure on operating one? Particularly on its sensors relation with Mach3, Do I need to address them in my codes?
Or is it being handle by the Spindle itself sort of a hard ware issue and not a software one?
regards
Offline TPS
  •  2,627 2,627
« Reply #3 on: May 04, 2018, 02:15:40 AM »
i do not know anything about your spindle,
but normaly there is a pneumatic valve for lock/unlock the tool,
and some Switches for tool locked and tool unlocked.
these switsches are noramly going to mach3 Inputs and then they have
to be controlled by M6 macro witch handles the ATC.
« Reply #4 on: May 04, 2018, 09:18:37 AM »
Hi TPS
thanks for the reply
this is what i thought to be, do you know what is the Script code that address them?
Let's say that i have dedicated Input4, Input5, and Input6 for my sensors.
do i need to address them in my M6 Codes, If yes please tell just the few lines needed for this matter.
also could it be like a Limit switch or Estop, that I do not need to address them and they just stop everything when they are turned on?
Regards
jhonansaro
« Reply #5 on: May 04, 2018, 09:54:33 AM »
Hi TPS
If I need to address them could it be done like below;
If IsActive(input4) Then
Code "M5"                         Trying to stop everything, If there is better way please let me know
End if
Exit the Sub
Regards
Offline TPS
  •  2,627 2,627
« Reply #7 on: May 04, 2018, 11:56:28 AM »
Hi TPS
Thanks again, but I already knew about these pdf files. Needless to say that they will take a lot of time to read.
Meanwhile I appreciate greatly, If you could clarify this sensor issue for me.
The codes that I posted before, is it going to do the Job? Do I need to add more lines?
Could you direct me to some sample codes on this matter?
regards
Offline TPS
  •  2,627 2,627
« Reply #8 on: May 04, 2018, 12:38:26 PM »
hello Johnansaro,
please dont missunderstand be, but i realy don't know (check) witch sensor issue i should clarify ???
the code you have posted will only do the following:
input4 i s on -> stop spindle (M5)
sorry i did not catch witch "Job" should do ???
« Reply #9 on: May 04, 2018, 01:12:09 PM »
Hi TPS
Thanks for the reply
and please forgive my lack of knowledge.
Ok what i was trying to do is as follow:
Let's say that I have connected my Chuck Open sensor to Input1 (I assume that they are On and Off Type of sensors), When it is off that things are Ok,
and it should proceed with ATC procedure,
But if it is on then What i think, I want to do is to shut off the Machine or sort of Estop it, I think M5 code just stops the spindle.
Please tell me if my logic is OK, should mention that my knowledge of ATC spindle is close to none, and I  need to work on it a lot, so please bare with me.
regards
« Last Edit: May 04, 2018, 01:15:14 PM by Johnansaro »
