Hello Guest it is November 07, 2026, 05:38:05 PM
Author Topic: Mach3 driver not install correctly on W7 32 bit.  (Read 32957 times)
« on: April 29, 2018, 01:37:31 PM »
Hi guys!
Now i'm having problem installing correctly Mach on Windows7 32 bit.
On system info , the driver shows with a question mark and this means " not intalled correctly".
I've change combatibyties on Win XP SP2, nothing but the same.
I cannot make my cnc run! Use parrallel port.
How can i solve this?
Any help will be really appreciated
Vasili
Re: Mach3 driver not install correctly on W7 32 bit.
« Reply #1 on: April 29, 2018, 11:51:28 PM »
a couple of days ago you were asking about a Chinese USB board, now your talking about a parallel port?
Which one are you trying to get to go?. You cant have both running at the same time.
« Reply #2 on: April 30, 2018, 02:52:09 AM »
Different PC, different BOB my friend!
« Reply #3 on: April 30, 2018, 06:01:11 AM »
What do i need to install correctly?
« Reply #4 on: April 30, 2018, 06:15:09 AM »
have you read the Mach3 Install Manual? In particular:
2.1.3 The Vital Reboot
You must reboot Windows before running Mach3. This reboot is vital. If you do not do it, you will get
into great difficulties which can only be overcome by using the Windows Control Panel to uninstall the
driver manually. So please reboot now.
If you are interested in knowing why the reboot is required, then read on. If not, you can skip to Sec
« Reply #5 on: April 30, 2018, 09:36:46 AM »
Hi
I did reboot at the end of the installation, but the question mark remains.....
« Reply #6 on: April 30, 2018, 01:50:42 PM »
the reboot is required and its not actually at the end. Re-read the Installation Manual. You'll now have to dig the corrupt driver out manually.
« Reply #7 on: April 30, 2018, 04:58:38 PM »
I seem to recall a message here last week that the latest Windows7 update causes the parallel port to not work with Mach3.
« Reply #8 on: May 01, 2018, 01:38:02 AM »
Hi Craig!
I do reboot as the manual sais with no luck from the beggining !
Gerry, please tell me which SP need to be installed to W7 to work properly?
Thank you guys for your help!
Vasili
« Last Edit: May 01, 2018, 01:54:17 AM by cncman »
Offline TPS
  •  2,627 2,627
