Hello Guest it is October 23, 2026, 04:02:46 PM
Author Topic: Mach3 driver not install correctly on W7 32 bit.  (Read 32491 times)
Re: Mach3 driver not install correctly on W7 32 bit.
« Reply #10 on: May 01, 2018, 07:20:34 AM »
Hmmm , still getting question mark on driver.......
Offline TPS
  •  2,627 2,627
« Reply #11 on: May 01, 2018, 10:13:40 AM »
installed a fresh mach3?
« Reply #12 on: May 01, 2018, 10:15:24 AM »
Yes!
« Reply #13 on: May 01, 2018, 12:59:44 PM »
you might try the 'Search' function, with it I found this:
http://www.machsupport.com/forum/index.php/topic,6346.0.html
There is, or used to be, a list of things you could do to improve your PC for parallel port operation. I'm sure if you spent some time
searching for it you could find it.
« Reply #14 on: May 01, 2018, 04:00:41 PM »
Thank you Craig, i'll check it and i'll come back!
« Reply #15 on: May 02, 2018, 03:34:00 AM »
Nothing happens at all! I had to install Win XP to make it run properly! I've seen many pc's running Win7 with no problem and i'm still wondering......why?
« Reply #16 on: May 02, 2018, 03:51:54 AM »
I ran Mach3 and two parallel ports on Windows7 for three plus years without problems. Did you find a copy of he optimization list....it had about 30-40m items on it?
Anyway you've got XP to work. If you were really concerned you'd ditch the parallel port altogether and get a genuine SmoothStepper or UC300 or 57CNC,
not some Chinese rubbish, then you could use just about any PC and Windows OS you care to name.
  •  9,374 9,374
« Reply #17 on: May 02, 2018, 04:25:59 AM »
Hi Cncman,
Did you remove the offending update (as TPS linked) from your Win7 installation ?
http://www.machsupport.com/forum/index.php/topic,37050.0.html
« Reply #18 on: May 02, 2018, 04:31:34 AM »
I thought the symptom of a Windows7 update was that as soon as you attempted to run the PP driver the PC rebooted. That is different to
what is described by the OP.
« Reply #19 on: May 02, 2018, 05:27:02 AM »
Craig, this is my next order! i know these BOB's and their quality. The PC is seeing the PP as well, but Mach3 cannot communicate with BOB! I tried EVERYTHING whith no luck at all! XP was the solution!
Tweaky, yes i did and nothing happens at all! I think Ordering from here and after is to order good BOBs and not cheap!
Thank you guys for your help indeed!
Vasili
