Hello Guest it is October 20, 2026, 06:44:21 PM
Author Topic: m10 m11 commands  (Read 11297 times)
m10 m11 commands
« on: April 24, 2018, 07:04:12 AM »
Can anyone tell me, because I'm new to mach3, these commands don't work for me.
I have output 2 enabled.
I type into the run box on the diagnostics screen M10P2 and M11P2 nothing happens. I expect 1 of the output leds to illuminate.
Is there some other setting I need to alter?
  •  9,374 9,374
Re: m10 m11 commands
« Reply #1 on: April 24, 2018, 07:21:49 AM »
Those commands only take effect at the instant of axis (any axis) movement.
For example, the Gcode;
G0 X0
M11P2
G0 X1
Would turn ON Output #2 at the instant axis X starts to move to position X1 and;
M10P2
G0 X0
Would turn OFF Output #2 again at the instant axis X starts to move to position X0.
There are more details here;  http://www.cooperman.talktalk.net/files/27_files/Page652.htm
http://www.tweakie.byethost10.com/27_files/Page652.htm
Hope this helps,
EDIT;  Link updated.
« Last Edit: July 03, 2019, 03:08:29 AM by Tweakie.CNC »
« Reply #2 on: April 24, 2018, 07:25:42 AM »
Thank you that helps a great deal.
I didn't understand the full context.
« Reply #3 on: April 24, 2018, 12:54:09 PM »
Tweakie thanks
I have just tried those codes this evening but without success.
I even cut and pasted your code in the post to a file and ran it.
The line after M11P2 didn't appear in the Mach3 code window and output 2 remained dormant.
On the plus side I read though your website and was very impressed with all you have done, both construction of your machine and products made on it.
  •  9,374 9,374
« Reply #4 on: April 24, 2018, 01:35:26 PM »
A couple of points that may help...
All Mach3 Gcode must finish with a CR so it is usual to insert a null character such as % at the end of every file. If you do not do this then the last line of code will be ignored.
The Diagnostic LED's do not always work as expected so a Meter (or similar) connected to the mapped Output Pin may provide a better indication.
You need to be using Mach3 version .056 or later.
