Mach Discussion => General Mach Discussion => Topic started by: plasmashine on April 24, 2018, 08:04:12 AM
Can anyone tell me, because I'm new to mach3, these commands don't work for me.
I have output 2 enabled.
I type into the run box on the diagnostics screen M10P2 and M11P2 nothing happens. I expect 1 of the output leds to illuminate.
Is there some other setting I need to alter?
Those commands only take effect at the instant of axis (any axis) movement.
For example, the Gcode;
G0 X0
M11P2
G0 X1
Would turn ON Output #2 at the instant axis X starts to move to position X1 and;
M10P2
G0 X0
Would turn OFF Output #2 again at the instant axis X starts to move to position X0.
There are more details here; http://www.cooperman.talktalk.net/files/27_files/Page652.htm
http://www.tweakie.byethost10.com/27_files/Page652.htm
Hope this helps,
EDIT; Link updated.
Thank you that helps a great deal.
I didn't understand the full context.
Tweakie thanks
I have just tried those codes this evening but without success.
I even cut and pasted your code in the post to a file and ran it.
The line after M11P2 didn't appear in the Mach3 code window and output 2 remained dormant.
On the plus side I read though your website and was very impressed with all you have done, both construction of your machine and products made on it.
A couple of points that may help...
All Mach3 Gcode must finish with a CR so it is usual to insert a null character such as % at the end of every file. If you do not do this then the last line of code will be ignored.
The Diagnostic LED's do not always work as expected so a Meter (or similar) connected to the mapped Output Pin may provide a better indication.
You need to be using Mach3 version .056 or later.
