Hello Guest it is October 21, 2026, 11:40:59 AM
Author Topic: mach3 tool table and CAM program  (Read 7525 times)
« on: April 20, 2018, 03:11:08 PM »
Greetings,
I have read a lot of posts on this forum and I cannot understand the tool table of mach3. Can anybody explain this to me like to a dumb person?
Let's say I have a square part with a hole in the middle through the part the hole is a 20mm H7.
In the cam program, I have 2 tools.
The first tool is a face mill 50mm
The second tool is a 6mm end mill.
And I make a g code with these two tools. The first question appears, does the g-code writes the parameters of the tools into the mach3 program (tool table)
 or do I have to manually put the tools in mach3 and when I make the g code I have to consider which tools are set up in mach3 on which position?
The second question is if I set up the 6mm tool and i want to make the hole exactly 20mm with tolerances H7 I set the second tool diam. Wear a slight +?
So I can then measure the hole and lower the diam. Wear for the difference that I measured?
Best regards and thank to all of you
Offline Davek0974
  •  2,606 2,606
Re: mach3 tool table and CAM program
« Reply #1 on: April 20, 2018, 03:21:57 PM »
You would load the data into the tool table yourself before setting up the job.
If i wanted a precise hole 20mm dia i would machine slightly undersize then ream it out with a  reamer :)
