Hello Guest it is November 23, 2026, 01:14:01 PM
Author Topic: Need Stop before running script  (Read 19723 times)
Offline olf20
  •  325 325
« on: April 17, 2018, 07:22:43 PM »
I have a my probe homing script working and the only
thing I need to finish is;
For some reason the homing script will not
run until I hit stop, then reset.
I have noticed that on the MDI screen that I
can not enter a move until a stop, reset is
done also.
Am I missing something or just need to include
it in my program???
Thanks for any help!
olf20 / Bob
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
Offline TPS
  •  2,627 2,627
Re: Need Stop before running script
« Reply #1 on: April 18, 2018, 12:39:59 AM »
sounds like a endless Loop in your code.
post your code and we will see.
Offline olf20
  •  325 325
« Reply #2 on: April 18, 2018, 05:56:22 AM »
I'll have to get it from the shop today.
This is only when I first start M3.
Once a stop / reset is hit everything
works.
olf20 / Bob
Offline olf20
  •  325 325
« Reply #3 on: April 18, 2018, 10:02:09 AM »
Attached is the script.
Some of what in the script
was for Z height setting.
I have not cleaned it up yet.
Thanks again
olf20 / Bob
'Check oemdro# And oemled#
SetOEMDRO(800,0.5)
SetOEMDRO(801,0.5)
SetOEMDRO(802,2.0)
Sleep(100)
CurrentFeed = GetOemDRO(818)    'Get the current feedrate.
PlateThickness =1.250      'Set gauge thickness
ProbeFeed = 20         'Set feedrate during probing
Code "G90 F" &ProbeFeed      'Set to Absolute Distance mode
'X Axis Home
If GetOemLed (825)=0 Then   'Check LED to see probe is ready
Code "G4 P1"                   'Time to get to the X-plate
Code "G31X4 F" &ProbeFeed   'Start X probe routine
While IsMoving()      'Probe moving X axis
Sleep(100)
Wend            'End of move
Code "G4 P0.25"         'Pause
XProbePos = GetVar(2000)   'Get position of probe
Code "G0 X" &XProbePos
While IsMoving ()      'Axis moving
Wend            'End of move
Call SetDro (0, PlateThickness)   '?
SetOEMDRO(800,0)      'Set X DRO for correct direction
Code "G4 P0.5"          'Pause for Dro to update.
Code "G0 X-1.065"                 'Change the X retract distance here
Code "(X axis is now homed)"
'Code "F" &CurrentFeed      'Store current feedrate to F
Code "G54 P2"
End If
'Y Axis Home
Sleep(1000)          'Sleep to finish X routine
'Code "G4 P1"                    'Time to get to the  Y-plate
Code "G31Y4 F" &ProbeFeed   'Start Y probe routine
While IsMoving()      'Probe moving Y axis
Wend            'End of move
YProbePos = GetVar(2001)   'Get position of probe
Code "G0 Y" &YProbePos
While IsMoving ()
Wend
Call SetDro (1, PlateThickness)
SetOEMDRO(801,0)
Code "G0 Y-6.820 F20"       'Change the Y retract distance here
Code "(Axis is now homed)"
Code "G54 P2"         'Pause to let code finish
Sleep(6000)         'Sleep to let program catchup
SetOEMDRO(800,8.8641)      'Set X work offset for Spoons
SetOEMDRO(802,2)      'Set Z work offset for All
SetOEMDRO(801,0.0000)      'Set Y work offset for Spoons
Else
Code "(Plate is grounded, check connection and try again)"
Exit Sub
End If
Code "X0 Y0"            'Ready to make spoons
« Last Edit: April 18, 2018, 10:04:05 AM by olf20 »
Offline TPS
  •  2,627 2,627
« Reply #4 on: April 18, 2018, 10:35:21 AM »
made some changes to your code, pls test
Code: [Select]
'Code"1003"
SetOEMDRO(800,0.5)
SetOEMDRO(801,0.5)
SetOEMDRO(802,2.0)
Sleep(100)
'X Axis Home
Sleep(50)
Wend 'End of move
Sleep(50)
Wend 'End of move
Sleep(100) 'Pause for Dro to update.
Sleep(50)
Wend 'End of move
Else
End If
'Y Axis Home
Sleep(50)
Wend 'End of move
While IsMoving ()
Sleep(50)
Wend
SetOEMDRO(801,0)
Sleep(50)
Wend 'End of move
Code "(Y axis is now homed)"
Else
Exit Sub
End If
Sleep(50)
Wend 'End of move
Offline olf20
  •  325 325
« Reply #5 on: April 18, 2018, 01:24:22 PM »
Thanks for the reply.
I will try the code tomorrow.
My problem is not that the code does not work
right, it's that it will not run without
first hitting a stop, then reset, when
Mach3 is first started and only first started.
After that the code runs fine.
As I mentioned in my first post some
other functions will not work without
hitting a stop, reset.
Thanks again I really appreciate
your help!!
olf20 / Bob
Offline olf20
  •  325 325
« Reply #6 on: April 19, 2018, 09:04:54 AM »
Ran your changes today and the same thing happens.
Script will not run till I hit a stop first.
Hit Auto Z button and the dwell light
blinks for a second or two and then
nothing.
olf20 / Bob
  •  9,378 9,378
« Reply #7 on: April 19, 2018, 09:29:47 AM »
Hi Bob,
The problem may be Mach3 version specific. I had a similar issue back in 2012 which was only resolved by adding DoOEMButton(1003) towards the beginning of my code.
Offline olf20
  •  325 325
« Reply #8 on: April 19, 2018, 10:54:50 AM »
I think you are right.
As I posted earlier I'm not able to
enter any MDI commands either.
Thanks for everyone's help!
olf20 / Bob
Offline olf20
  •  325 325
« Reply #9 on: April 19, 2018, 04:41:31 PM »
Adding the stop to the beginning of the script solved
the problem.
Thanks TPS for guiding me on proper script writing.
olf20 / Bob
