Hello Guest it is September 06, 2026, 05:47:00 AM
Author Topic: spindle  (Read 10040 times)
spindle
« on: April 08, 2018, 06:13:55 PM »
I am new here and the spindle on my machine doesnt shut off automatically.....Is there a control pin or state pin for controlling/utilizing l spindle motor control.
George
Re: spindle
« Reply #1 on: April 08, 2018, 07:50:06 PM »
yes there are controls for the spindle but you've given us nothing about your machine or BoB or any thing else.
We aren't mind readers.
Are you using a parallel port?
What BoB are you using?
What type of spindle and spindle driver are you using?
Can you post manuals for the BoB and spindle driver?
Re: spindle
« Reply #2 on: April 09, 2018, 03:24:32 PM »
Sorry Craig:
I bought this machine used and know very little about it...The spindle is a router and as of now it is directly driven from the 110 power supply...
I want to have it so when the program starts it starts and when the program is finished i want it to stop....Its hard to walk away knowing the spindle won't stop
I am using parallel port and i know pins 2,3,4,5,6,7, are used for the x,y,z axis...I dont believe 8,9 are used and wonder if one of these pins can be used to control the spindle???
I have no idea what a BoB is
I have a person with computer knowledge but not a lot when it comes to cnc or Mach3...
Is there a mach 3 manual i can download and use to trouble shoot and repair problems that arise...
I don't know what else i can tell you since im new to this machine and program..It is a Gorilla machine if that means anything
George
Re: spindle
« Reply #3 on: April 09, 2018, 05:22:42 PM »
the breakout board (BoB) is what is plugged into the parallel port. It will have buffer/amplifiers on it and probably
a/some relay/s.
Can you take a photo. It is probable that there will be a defined output for the relay.
Re: spindle
« Reply #4 on: April 09, 2018, 07:11:53 PM »
You need a relay to turn the spindle on and off. You can control the relay with an output pin.
Re: spindle
« Reply #5 on: April 09, 2018, 07:17:36 PM »
that is what i've been thinking but i'm not sure i have a relay  so we will need to put one and can i just assign a pin to it (say pin 8)...I will take a pic tomorrow and post it for your consideration
Thanks for your help
George
