Hello Guest it is November 23, 2026, 04:06:51 AM
Author Topic: Mach3 wont fire torch on plasma table  (Read 37239 times)
« on: March 22, 2018, 02:51:31 PM »
We have a Plasma table from Plasmaroute CNC that has stopped firing the arc.  The Software is Sheetcam and Mach3.  The included hardware is a Thermal Dynamics 120A, plasmaoute's motion control box, and their PR301 (THC301) for our torch height control.  Everything was normal until about a week ago when Mach3 started making our computer crash upon opening the program.  We cleared a few new windows updates, then reinstalled Mach3 and Sheetcam.  Mach3 seems to act and read all the GCODE normal until it gets to an M03 or M05.  It pauses like it should, it just wont try to start the arc.  if i let the program run and i manually turn the torch on and off in mach3 it cuts just fine.  what could be the issue?  at this point i cant get ahold of plasmaroute and have ran out of ideas.  Thanks for any input
Offline TPS
  •  2,627 2,627
Re: Mach3 wont fire torch on plasma table
« Reply #1 on: March 23, 2018, 01:47:46 AM »
i dont know your System/Hardware, and found no documentation about plasmaroute control box,
but normaly there is an Output (i.E. spindlerelay) witch Switches the cutter on/off (via M3 macro)
so if you post some Information of your box, and some screenshots of ports&pins -> spindle Setup.
also your XML would be helpful.
« Reply #2 on: March 23, 2018, 09:26:36 AM »
http://www.cnc2all.com/downloads/TMC-THC301-Quick%20Start.pdf
This is the exact setup we run on our system to the best of knowledge
Offline TPS
  •  2,627 2,627
« Reply #3 on: March 23, 2018, 09:53:31 AM »
can you please post your XML file?
 the Manual says noting about the used Signal, exept
all the torch control is done via LPT port 2.
Thank You
« Reply #6 on: March 23, 2018, 10:02:54 AM »
that should be a screen shot of the ports and pins settings
Offline TPS
  •  2,627 2,627
« Reply #7 on: March 23, 2018, 10:04:09 AM »
not realy
Offline TPS
  •  2,627 2,627
« Reply #8 on: March 23, 2018, 10:06:09 AM »
you can save the Screenshot on your pc,
and use the Additional Options (left lower Corner)
when you post a reply to attach the file
« Reply #9 on: March 23, 2018, 10:09:44 AM »
hope i got it this time
