Hello Guest it is October 24, 2026, 10:34:45 PM
Author Topic: mach 3 turn  (Read 10144 times)
Offline Jacko
  •  43 43
mach 3 turn
« on: July 13, 2007, 04:27:33 AM »
I made a router using "mach 3 mill" and then scrapped that and converted my lathe with the bits i salvaged. I am now using "mach 3 turn" to run my lathe.  Every thing is working fine except that i cant jog the x axis.  The axis and dro move ok when i jog z but nothing moves when i try to jog the x axis, not even the dro. The lathe is working  fine and runs programs ok.  Have i had a dodgy download or do i need to configure something. The office computer that i originally download mach onto is the same. ie only the z axis will jog.
thanks in advance
jacko
Re: mach 3 turn
« Reply #1 on: July 22, 2007, 12:58:44 PM »
With the Mach3 Turn screens you can only jog on the Manual screen AND You have to have the Jogging on :(
Hope that helps..
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline Jacko
  •  43 43
Re: mach 3 turn
« Reply #2 on: July 23, 2007, 02:57:33 AM »
i have since downloaded the latest version and everything now works fine.
thanks
jacko
