Hello Guest it is September 23, 2026, 10:13:24 AM
Author Topic: Run from here does not work correct  (Read 8276 times)
« on: March 15, 2018, 07:48:49 AM »
 I have a problem with Mach3 and the function "run from here"
If i want to start the g code from another Line then the first, it takes minutes to get to the line.
For example a want to go to line 4350 and when i hit "run from here" Mach3 reads every line of the g code until he comes to line 4350.
What must i chance?
Re: Run from here does not work correct
« Reply #1 on: March 15, 2018, 07:52:27 AM »
In order to Run From Here correctly Mach must know exactly what every mode is active, what the feed rate is etc. It can only get that by looking at every preceeding line.
« Reply #2 on: March 15, 2018, 08:50:12 AM »
Ok,
but with my other machine and Mach3 i have not this problem.
When I hit "run from here", it jumps direct to the line and i can start from there.
Offline rcaffin
  •  1,073 1,073
« Reply #3 on: March 20, 2018, 03:29:25 AM »
'jumps direct' - how very odd. Perhaps you have a very old version of mach3 on your 'other' machine?
Roger
