Mach Discussion => General Mach Discussion => Topic started by: ThorstenU on March 15, 2018, 08:48:49 AM
I have a problem with Mach3 and the function "run from here"
If i want to start the g code from another Line then the first, it takes minutes to get to the line.
For example a want to go to line 4350 and when i hit "run from here" Mach3 reads every line of the g code until he comes to line 4350.
What must i chance?
In order to Run From Here correctly Mach must know exactly what every mode is active, what the feed rate is etc. It can only get that by looking at every preceeding line.
Ok,
but with my other machine and Mach3 i have not this problem.
When I hit "run from here", it jumps direct to the line and i can start from there.
'jumps direct' - how very odd. Perhaps you have a very old version of mach3 on your 'other' machine?
Roger
