Hello Guest it is November 10, 2026, 01:39:00 AM
Author Topic: G31Probing Arrays  (Read 8687 times)
G31Probing Arrays
« on: March 13, 2018, 06:25:30 AM »
good morning
I downloaded (in the section MACH TOOL BOX) G31Probing Arrays.zip for external / internal surveys, the macro G31IntPolArrayV2.01.txt does not give me problems, the macroG31ExtPolArrayV2.01.txt gives me error (I enclose) in the forum talk about a file M1289 .m1s I can not find it, can it be the problem?
solutions?
Re: G31Probing Arrays
« Reply #1 on: March 13, 2018, 06:26:48 AM »
« Reply #2 on: March 13, 2018, 06:31:15 AM »
« Reply #3 on: March 14, 2018, 04:07:45 PM »
That line SHOULD read as
#122=Fix[#122]
« Reply #4 on: March 14, 2018, 04:32:54 PM »
The only other thing you need is M1299 which sets up the Values for the arrays to use
« Reply #5 on: March 15, 2018, 02:22:36 AM »
OK it works well !!! I double checked in the MACH TOOL BOX section the file contains error.
thanks BR549 ;) ;)
