Hello
Guest
it is
October 21, 2026, 12:59:31 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Double touch when using auto zero. Plate grounded error.
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Double touch when using auto zero. Plate grounded error. (Read 22180 times)
TPS
2,627
Re: Double touch when using auto zero. Plate grounded error.
Reply #10 on:
March 12, 2018, 12:10:02 PM »
maybe this
Code "G91 G0
Y-.100
X1.0"
y movement is to small, to go down with z axis
this code is for right upper Corner?
Last Edit: March 12, 2018, 12:13:18 PM by TPS
Benjammann
25
Reply #11 on:
March 12, 2018, 12:13:12 PM »
I think it stops before it gets that far, but I'll give it a shot this evening.
Taig Micro Mill. 1/4-20" lead screw. Powered by 1.25hp router with a 4:1 pulley reduction. Driven by Ethernet SmoothStepper to a Gecko 6540. Nema 23 motors. 3 Axis.
TPS
2,627
Reply #12 on:
March 12, 2018, 12:14:15 PM »
Benjammann
25
Reply #13 on:
March 12, 2018, 12:25:34 PM »
Yes because my table travel is short so I have to locate in the middle of a part. But whenever I get it working ill take this code and transfer it to the other buttons for other corners.
Benjammann
25
Reply #14 on:
March 19, 2018, 07:54:37 AM »
Hey, Thanks for all your help. This was the solution!
Code "G90 G0 Z.500" 'retract Z to .500 inch
Code "G91 G0 Y-.100 X1.0"
Code "G90 G0 Z-.200"
Code "F" &CurrentFeed 'Returns to prior feed rate
While IsMoving ()
Wend
End If
yemil
21
Reply #15 on:
April 17, 2018, 10:13:36 PM »
hi .. i am sort of new on this..
just asking and learning....
i dont know much of these codes ...but i need a script for auto zeroing my mach3
could you post the entire script?
thanks in advance
Print
Pages:
1
2
Go Up
« previous
next »
