Hello Guest it is October 21, 2026, 12:57:12 PM
Author Topic: Double touch when using auto zero. Plate grounded error.  (Read 22176 times)
Offline TPS
  •  2,627 2,627
Re: Double touch when using auto zero. Plate grounded error.
« Reply #10 on: March 12, 2018, 12:10:02 PM »
maybe this
Code "G91 G0 Y-.100 X1.0"
y movement is to small, to go down with z axis
this code is for right upper Corner?
« Last Edit: March 12, 2018, 12:13:18 PM by TPS »
« Reply #11 on: March 12, 2018, 12:13:12 PM »
I think it stops before it gets that far, but I'll give it a shot this evening.
Taig Micro Mill. 1/4-20" lead screw. Powered by 1.25hp router with a 4:1 pulley reduction. Driven by Ethernet SmoothStepper to a Gecko 6540. Nema 23 motors. 3 Axis.
Offline TPS
  •  2,627 2,627
« Reply #12 on: March 12, 2018, 12:14:15 PM »
« Reply #13 on: March 12, 2018, 12:25:34 PM »
Yes because my table travel is short so I have to locate in the middle of a part. But whenever I get it working ill take this code and transfer it to the other buttons for other corners.
« Reply #14 on: March 19, 2018, 07:54:37 AM »
Hey, Thanks for all your help. This was the solution!
Code "G90 G0 Z.500" 'retract Z to .500 inch
   Code "G90 G0 Z-.200"
   Code "F" &CurrentFeed 'Returns to prior feed rate
  While IsMoving ()
   Wend
End If
Offline yemil
  •  21 21
« Reply #15 on: April 17, 2018, 10:13:36 PM »
hi .. i am  sort of new on this..
just asking and learning....
i dont know much of these codes   ...but i need a script for auto zeroing my mach3
could you post the entire script?
thanks in advance
