Hello Guest it is November 03, 2026, 09:16:20 PM
Author Topic: new control panel  (Read 37789 times)
new control panel
« on: March 07, 2018, 07:07:25 AM »
uses a 22.5 inch touch screen
« Last Edit: March 07, 2018, 07:17:51 AM by Tweakie.CNC »
Re: new control panel
« Reply #1 on: March 07, 2018, 07:13:45 AM »
I dont know why the picture didn't appear in the vertical position? I can seem to change it
« Last Edit: March 20, 2018, 07:27:43 AM by Tweakie.CNC »
  •  9,375 9,375
« Reply #2 on: March 07, 2018, 07:19:19 AM »
Done.  ;)
Excellent control panel.
« Reply #3 on: March 07, 2018, 07:34:41 AM »
Here I'm milling the button holes.
« Last Edit: March 20, 2018, 07:24:35 AM by Tweakie.CNC »
« Reply #4 on: March 12, 2018, 02:15:29 PM »
Mach3 seems to conform to the vertical screen. but the boxes need some resizing.
I don't thing the touch screen likes windows xp as its acting goofy
probably gonna switch computer to something more sutable to mach 4
first picture is suppose to be vertical??
« Last Edit: March 20, 2018, 07:26:08 AM by Tweakie.CNC »
« Reply #5 on: March 20, 2018, 06:55:34 AM »
Started moving the buttons around in Mach 3. i started with the factory  1024 screen set.
My workstaton is a board on to of a garbage can.
Do know why the pictures dont post in proper position??
« Last Edit: March 20, 2018, 07:23:12 AM by Tweakie.CNC »
  •  9,375 9,375
« Reply #6 on: March 20, 2018, 07:31:27 AM »
It makes it easier to view so I have rotated your pictures.  ;)
Offline jeep534
  •  123 123
  • From the hills of WV
« Reply #7 on: March 20, 2018, 09:46:31 PM »
That is an awsum control panel. what machine is that on
Thank You
archie
Facebook archies machine
« Reply #8 on: March 21, 2018, 06:19:17 AM »
It's a Bridgeport Series 1 R2E3
When i got it the DC power supply was shorted. So i replaced everything with new controls but keep the Factory DC servos.
Ethernet Smooth stepper, CNCDrives servo drivers, 80 volt DC power supply. AMT-102 encoders. Used the factory enclosure and servo cables.
Automation direct VFD single phase to 3 phase so I'm using the original motor.
  •  9,375 9,375
« Reply #9 on: March 21, 2018, 07:10:19 AM »
 ;D
