Hello Guest it is October 23, 2026, 06:16:03 PM
Author Topic: Is there "Driver Test" in Trial Mach3  (Read 9807 times)
« on: March 02, 2018, 11:27:44 AM »
hello, I have spent at least 3 hours looking and cant find the " Driver Test program". Is it in the trial version of Mach3? What I have is a Gecko G540, UC100 controller, windows 10 64 bit laptop.
thanks in advance for the help.
Re: Is there "Driver Test" in Trial Mach3
« Reply #1 on: March 02, 2018, 12:10:43 PM »
DriverTest.exe is a means of testing a parallel port. You don't (can't) have a parallel port ergo DriverTest.exe won't work. It should still be in the main
Mach3 folder.
  •  9,374 9,374
« Reply #2 on: March 03, 2018, 12:46:09 AM »
Hi Bigforkg,
When you installed Mach3 for use with UC100 you would not have installed the Parallel Port drivers so DriverTest.exe would not have been copied into your Mach3 folder.
« Reply #3 on: March 03, 2018, 09:18:47 AM »
Thank you Crig and Tweakie
What about the " blue screen of death" in the mach3 manual? Is that not a factor because of the UC100?
« Reply #4 on: March 03, 2018, 10:56:56 AM »
No. Or yes?
You don't have to worry about the Drivertest with the UC100.
