Hello Guest it is November 21, 2026, 11:29:32 AM
Author Topic: Mach4, ESS smoothstepper and PMDX126 - spindle starts but then stops  (Read 8483 times)
Hi all,
I had problems with my spindle drive which ended up being the transformer for the drive which has now been replaced. Prior to this I was trying all kinds within Mach4 in the hope that it was a software setting and not the drive.  Now when I start the spindle it instantly stops again.  Can anyone give me any pointers on what to look for to resolve this?
Regards
Steven
Offline thosj
  •  542 542
Re: Mach4, ESS smoothstepper and PMDX126 - spindle starts but then stops
« Reply #1 on: March 01, 2018, 06:53:38 AM »
Do you use a PMDX-107 for the spindle?
Tom
« Reply #2 on: March 01, 2018, 07:01:09 AM »
Yes I am using a PMDX-107 for spindle.  I had it running before the transformer on the spindle drive packed up.
Offline thosj
  •  542 542
« Reply #3 on: March 01, 2018, 07:20:23 AM »
https://warp9td.com/index.php/kunena/7-general-discussion/6442-mach3-ess-pwm-spindle-problem
https://www.pmdx.com/PMDX-Forums/index.php?topic=305.0
Grab a cup of coffee! Not sure any of this is relevant to your situation.
Contact Steve Stallings via email, he WILL help you.
Tom
Tom
« Reply #4 on: March 01, 2018, 09:27:24 PM »
how about fitting a voltmeter on the output of the 107 to see if the analogue voltage is persistant.
If it is it suggests that the VFD is faulting out.
