Hello Guest it is November 13, 2026, 05:28:35 PM
Author Topic: PoKeys homing limit switch issues  (Read 33478 times)
Offline NeoTO
  •  504 504
    • PoLabs
Re: PoKeys homing limit switch issues
« Reply #10 on: March 05, 2018, 02:40:07 PM »
So, you configured 2000 pulses for the Z-axis (or only X?) back-off distance using PoKeys application and the motor doesn't back off from the switch after homing?
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
« Reply #11 on: March 05, 2018, 03:30:02 PM »
i set all axis at 2000 no the motor does not back off
« Reply #12 on: March 14, 2018, 04:52:03 PM »
i still have not been able to get  the axis to back off switch
« Reply #13 on: June 22, 2018, 05:33:20 PM »
I am  having the same problem  No backing off after it hits the limit during homing.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #14 on: July 15, 2018, 11:12:33 PM »
Was the issue solved?
Did you configure the back-off distance using the PoKeys application?
« Reply #15 on: July 16, 2018, 08:19:06 AM »
Got it!  Two switches are wired but only 1 is mapped.
