Hello Guest it is October 21, 2026, 08:04:54 AM
Author Topic: Scripter Compile Error bites again :(  (Read 208380 times)
Offline rcaffin
  •  1,073 1,073
Re: Scripter Compile Error bites again :(
« Reply #70 on: March 15, 2018, 05:46:43 AM »
Hi Craig
I started writing in Assembler around 1970.  At one stage I 'knew' just about every microprocessor language - and then gave up tracking the ones which I knew were not going anywhere. I also knew most standard high-level languages until they too got boring (being little more than variants on each other).
I have written everything from device drivers to science packages to database systems (not the app, the system), robot and machine controllers, image analysis systems, ...
I have debugged OSs, compilers and ...  Both the first OS and the compiler were fun, as I was able to tell the vendor exactly where the bug was without the source code.
Now - I am retired.
So yes, I know what a disassembler can and cannot do. I agree with the limits you gave.
Mind you, decompiling C is not that hard: there is little difference between the two!
Roger
Offline Davek0974
  •  2,606 2,606
« Reply #71 on: March 17, 2018, 10:40:45 AM »
I had a small run of parts on the mill today, about 15 tool changes in all - all worked perfectly, no scripter errors.
Too early to say fixed or not but it's promising.
Offline Davek0974
  •  2,606 2,606
« Reply #72 on: March 18, 2018, 08:36:15 AM »
Running again this morning - still no sign of trouble :)
« Reply #73 on: March 19, 2018, 04:14:24 AM »
Fingers crossed!
Mike
Offline TPS
  •  2,627 2,627
« Reply #74 on: March 24, 2018, 04:52:29 AM »
hello Dave,
you wrote that you are using rigid tapping
with cs lab enc module?
in G84 or with M84 ?
Thomas
Offline Davek0974
  •  2,606 2,606
« Reply #75 on: March 24, 2018, 05:44:44 AM »
Hi
yes, I modded my posts to output M84
Offline TPS
  •  2,627 2,627
« Reply #76 on: March 24, 2018, 05:47:48 AM »
Hi Thank you for the reply,
if i use M84 my System allways get stuck.
Offline Davek0974
  •  2,606 2,606
« Reply #77 on: March 24, 2018, 06:29:50 AM »
Have you got the full M84 output code?
Should appear like this...
M84 Q11.262 P0.8 S350 R350
Offline TPS
  •  2,627 2,627
« Reply #78 on: March 24, 2018, 06:53:11 AM »
what a actual do is:
Z = 0
then
M3
M84 P2 Q-20 S50 R100
i suggested that it will go to -20 and then go back
but it goes to -20 spindle stops wait for the 2 sek start's spindle CW again
and goes with f200 further down (Z-) until i press stop
Offline Davek0974
  •  2,606 2,606
« Reply #79 on: March 24, 2018, 07:56:24 AM »
Take the M3 out, the spindle is controlled internally by the M84 routine - its scary but does work ;)
Your parameters are in the wrong order too :)
Should be M84 Q P S R
