Hello Guest it is October 21, 2026, 09:14:08 AM
Author Topic: Scripter Compile Error bites again :(  (Read 208387 times)
Offline TPS
  •  2,627 2,627
Re: Scripter Compile Error bites again :(
« Reply #30 on: March 13, 2018, 06:08:48 AM »
just a question, how does your Cam create M3 call's?
M3 S1234 or
S1234
M3
Offline Davek0974
  •  2,606 2,606
« Reply #31 on: March 13, 2018, 06:22:27 AM »
What about CS Labs new software?
They have one in Beta, I have it downloaded, have not tried it because it has limited functionality, no macro editing and no screen editing - i could not use it on my mill without these functions.
They say it will all be there but after the beta stage is done so no idea when.
Offline Davek0974
  •  2,606 2,606
« Reply #32 on: March 13, 2018, 06:23:18 AM »
M3 S1234 or
S1234
M3
(END PROFILES)
N10 M5
N12 M9
N14 T3 M6
N16 S4000 M3
N18 G54
N20 M7
N24 G0 X232.214 Y5.999.........
Offline TPS
  •  2,627 2,627
« Reply #33 on: March 13, 2018, 06:46:44 AM »
i have changed this on my machines to
S1234
M3
years ago, but realy can't remember why.
Offline Davek0974
  •  2,606 2,606
« Reply #34 on: March 13, 2018, 06:50:53 AM »
Interesting, its the same format in my Vectric code too.
Offline TPS
  •  2,627 2,627
« Reply #35 on: March 13, 2018, 06:58:13 AM »
during trying to remember why i did this, i was googling arround,
and found this:
https://www.machsupport.com/forum/index.php?action=printpage;topic=28339.0
Offline Davek0974
  •  2,606 2,606
« Reply #36 on: March 13, 2018, 07:47:07 AM »
Interesting, more food for thought.
Offline Davek0974
  •  2,606 2,606
« Reply #37 on: March 13, 2018, 01:25:18 PM »
I have saved all my macro's as .mcc files and deleted all the .m1s copies.
Will see if that makes any difference.
BTW do not do this to macropump.m1s - it stops it running ;)
Offline rcaffin
  •  1,073 1,073
« Reply #38 on: March 13, 2018, 03:50:39 PM »
Interesting.
I write my own g-code programs (out of my head) and use the following format:
f100 s2000
m3
As far as I can remember, this has never given the Scripter Compile error.
But playing around with the g84 command seems a bit risky as it is greyed out in the manual, meaning it never got passed Art's checking (or Brian's?). Obviously there was a bug in it they could not find. My spindle can't do tapping anyhow (DC servo, not suited to those speeds) so I thread mill instead. Yeah, slower.
On the other hand, if I launch Mach3 .062 and go straight into a program, the first Spin parameter can be missed, with the spindle going to max speed. If I spin the spindle up just once by hand first, all is well for the rest of the day. There is a funny in there somewhere. (Just one???)
Roger
Offline Davek0974
  •  2,606 2,606
« Reply #39 on: March 13, 2018, 04:05:06 PM »
I don't mind messing with post coding but, and thats a big but, i probably will not do it as this is a random issue - if the code was wrong it would fail, every time. This issue seems to have a bit of luck attached to it - most of the time it will work, then fail, i've had it mostly fail in the middle of the day i.e. not right on start-up so it will have done many starts and stops but then just decide to fail, most of the time in the middle of a code file.
All the apps i post code with have the same format so i can't see how it can be that.
My CS-LABS controller has a custom code M84 instead of G84 - pretty certain the rigid tapping is done directly in the controller not Mach.
