Hello Guest it is November 23, 2026, 05:08:57 AM
Author Topic: Scripter Compile Error bites again :(  (Read 210769 times)
Re: Scripter Compile Error bites again :(
« Reply #10 on: February 19, 2018, 01:39:03 PM »
Hi Dave,
one of the arguments in favour of Mach4 is that Lua is stable.
Offline Davek0974
  •  2,606 2,606
« Reply #11 on: February 19, 2018, 01:46:40 PM »
Hmmm.....
Offline rcaffin
  •  1,073 1,073
« Reply #12 on: February 27, 2018, 03:38:30 AM »
Thomas's suggestion 'feels' right.
Try putting 'end <LF> at the end (ie a comment).
Roger
Offline Davek0974
  •  2,606 2,606
« Reply #13 on: February 27, 2018, 09:07:39 AM »
I deleted the file, made a new one with a couple of returns after the code.
Not had the issue again yet.
Offline Davek0974
  •  2,606 2,606
« Reply #14 on: March 12, 2018, 01:47:10 PM »
And.....It's back :(
Ran all day yesterday, not a hint of trouble. Tonight I had one quick job and this time I get no tool length compensation.
The error message this time was "scripter compile error in M6End.m1s" - this is why no TLC as that is in my M6End macro.
Now, last time the M3.m1s played up I saved it as M3.mcc which i believe is pre-compiled?
Seems odd that it now failed on the M6 macro - I have now saved both M6Start & M6End as .mcc files - in the vain hope that it will stop it doing it again. Of course there will always be another macro to fail I guess. :(
Offline TPS
  •  2,627 2,627
« Reply #15 on: March 12, 2018, 02:41:34 PM »
witch Version of Mach3 are you running?
Offline Davek0974
  •  2,606 2,606
« Reply #16 on: March 12, 2018, 02:45:41 PM »
V062
Offline TPS
  •  2,627 2,627
« Reply #17 on: March 12, 2018, 02:49:11 PM »
ok i turn the "i know something better" mode ON again,
v022 and i am happy with it
"i know something better" mode OFF
Offline Davek0974
  •  2,606 2,606
« Reply #18 on: March 12, 2018, 02:57:22 PM »
Yes it has been mentioned before, trouble is, i can't find out what, if any, things may stop working or not work how I expect when downgrading - this i s a fairly customised setup I think and I don't want to risk buggering something up ;)
Also, where do i find the old version?
Offline rcaffin
  •  1,073 1,073
« Reply #19 on: March 12, 2018, 03:39:34 PM »
You do know that if you bring up the Operator/VB Script Editor you can run the M6End macro from there, and it will (normally) stop at the problem line?
Roger
