Hello Guest it is November 13, 2026, 01:48:00 PM
Author Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA  (Read 293184 times)
Offline TPS
  •  2,627 2,627
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« Reply #150 on: February 27, 2018, 01:41:09 PM »
ok, back again,
i think we can use your M3.m1s macro for the Job:
copy this code to macro before the dospinCW()
   pierceHeight = 0.5 'enter here a value for wanted pierceheiht
   code "F30"
   code "G31 Z-1"
   While Ismoving()
   Wend
   code "G00 Z" & GetVar(2002) 'go back to the  probepoint
   While Ismoving()
   Wend
   code "G91 Z-" & pierceHeight
   While Ismoving()
   Wend
   code "G92 Z0"
   While Ismoving()
   Wend
   Code "G90"
« Reply #151 on: February 27, 2018, 02:41:07 PM »
i got a an error, it said syntax error, and wouldnt run and gcode files
Offline Davek0974
  •  2,606 2,606
« Reply #152 on: February 27, 2018, 02:43:21 PM »
Did you copy/paste or type it?
seems ok to me
« Reply #153 on: February 27, 2018, 02:48:19 PM »
I copy and pasted it
« Reply #154 on: February 27, 2018, 02:57:07 PM »
It worked!!!!!!!
« Reply #155 on: February 27, 2018, 02:57:36 PM »
I think I may have changed a setting in MACH that I shouldn’t have, I reset Mach and it worked!
« Reply #156 on: February 27, 2018, 03:01:13 PM »
Running test cysts right now, it’s working amazing. Now just to set my THC back up!
« Reply #157 on: February 27, 2018, 03:17:37 PM »
Hooked my PROMA back up, I’m back to where I was before I decided to add a floating head, the THC is working correctly, but seems to lose it Z after the first pierce.. it’s still diving itself into the material. (Just lost a limit switch.. RIP. good thing I ordered5)
« Reply #158 on: February 27, 2018, 03:28:34 PM »
My work offset Z is stuck at 1.7477. I can reset, ZERO, and it keeps jumping back to 1.7477
« Reply #159 on: February 27, 2018, 03:46:05 PM »
So, with my THC atttached, after it probes for z, it goes back up to where the probe started, then it dives down instead of going up to my pierce height..?
