Hello Guest it is September 30, 2026, 08:01:22 AM
Author Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA  (Read 284288 times)
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« Reply #90 on: February 15, 2018, 12:17:25 PM »
I can fire plasma and manually jog, THC runs great. But when I run gcdoe, it dives into material
« Reply #91 on: February 15, 2018, 12:29:22 PM »
It’s only allowing the Z axis to move up half the distance it should, which then drives t down the full distance into the material. Any ideas?
Offline Davek0974
  •  2,606 2,606
« Reply #92 on: February 15, 2018, 12:30:43 PM »
Increase your voltage on the proma 2 or 3v and try again.
Did you do a test cut to establish the correct voltage?
« Reply #93 on: February 15, 2018, 12:34:55 PM »
Yes! 160 ish seems about right.
Offline TPS
  •  2,627 2,627
« Reply #94 on: February 15, 2018, 12:35:21 PM »
somewhere i found this:
Offline TPS
  •  2,627 2,627
« Reply #95 on: February 15, 2018, 12:38:07 PM »
can you pls post your GCode , maybe something is wrong there.
Offline Davek0974
  •  2,606 2,606
« Reply #96 on: February 15, 2018, 12:38:52 PM »
That was the voltage displayed while doing a straight cut with the THC turned off in Mach3 over a reasonable distance like 200-300mm??
« Reply #97 on: February 15, 2018, 12:45:05 PM »
It’s acting kind of weird. It’s working sometimes, other times not. Sometimes it dives, sometimes it doesn’t.
« Reply #98 on: February 15, 2018, 12:48:20 PM »
« Reply #99 on: February 15, 2018, 12:51:08 PM »
see its weird, even if i uncheck the THC boc on the plasma screen., the THC still functions the same as if the THC button was on.
