Hello Guest it is November 13, 2026, 01:02:00 PM
Author Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA  (Read 293100 times)
0 Members and 8 Guests are viewing this topic.
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« Reply #70 on: February 15, 2018, 10:46:59 AM »
If I go into config-> ports pins -> input, and disable all the THC ON THC UP THC DOWN inputs, then restart mach3, the SAME EXACT GCODE FILE will run no problems.
Offline TPS
  •  2,627 2,627
« Reply #71 on: February 15, 2018, 10:49:35 AM »
are you sure THC ON is comming when Plasma fires ?
Mach will wait for this signal until it starts X/Y
« Last Edit: February 15, 2018, 10:53:50 AM by TPS »
« Reply #72 on: February 15, 2018, 10:55:43 AM »
No, my output 1 lights up, that’s how it is when it runs normally thought.
Offline TPS
  •  2,627 2,627
« Reply #73 on: February 15, 2018, 10:57:05 AM »
you mave to make sure THC ON is comming ortherwise X/Y will wait for it.
can you post your M3 macro ?
« Reply #74 on: February 15, 2018, 10:58:31 AM »
How can I make sure of this? Any if that’s the case then why won’t Mach wait for it when’s THC ON isn’t enabled?
What is my M3 MACRO? Sorry.
Offline TPS
  •  2,627 2,627
« Reply #75 on: February 15, 2018, 11:03:56 AM »
here a part of Mach3Mill_Install_Config Manual Appendix A Torch Height Controls
in Mach3
Notes:
• Turning spindle ON sets the THC correction to zero. Min/Max step counts are then effective from
the current Z.
• Only licensed versions can enable THC mode.
• When in THC mode, motion will not begin until THCON (Torch OK) signal becomes active.
Motion may be delayed by Pierce Delay.
• Pierce Delays tells the system not to move until delay seconds have passed since spindle (torch)
was turned on.
• Config/spindle Torch AutoOff setting shortens delay in takeoff, and also turns off torch automatically
if motion stops.
Offline TPS
  •  2,627 2,627
« Reply #76 on: February 15, 2018, 11:11:09 AM »
don't ask i haven' done the Software for that THC controll in Mach
c:\Mach3\Macros\your Profile Name\M3.M1S
« Reply #77 on: February 15, 2018, 11:16:34 AM »
in Mach3
Notes:
the current Z.
was turned on.
if motion stops.
I’m not sure where to even go from this..
« Reply #78 on: February 15, 2018, 11:16:57 AM »
I am getting my macros onto a zip right now I will post them asap
Offline TPS
  •  2,627 2,627
« Reply #79 on: February 15, 2018, 11:21:50 AM »
this is the only part witch is  urgent for now:
Notes:
