Hello Guest it is November 13, 2026, 12:17:06 PM
Author Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA  (Read 293021 times)
Offline Davek0974
  •  2,606 2,606
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« Reply #20 on: February 10, 2018, 12:17:00 PM »
All of my parts on my table are custom parts every time so I make a new zero every time
This is all personal setup - all my stuff is original etc but i always home first, it has allowed me to save jobs after a problem or two ;)
« Reply #21 on: February 10, 2018, 12:17:48 PM »
Okay I will hook it up like that right now. My proma is already hooked up measuring voltage!
Offline Davek0974
  •  2,606 2,606
« Reply #22 on: February 10, 2018, 12:19:50 PM »
Great- you got the dangerous bit working OK :)
the rest is just simple inputs, nothing more. you can even debug by replacing the proma with simple push switches - all you need is to get proper up & down control of the Z axis.
« Reply #23 on: February 10, 2018, 12:20:57 PM »
Thanks a lot you’ve helped a ton. I’m gonna mess around with this thing for a few and I’ll let you know if I run into promblems! Thank you!
« Reply #24 on: February 10, 2018, 12:26:02 PM »
For COM, I connect this to the ground on my power supply?
Offline Davek0974
  •  2,606 2,606
« Reply #25 on: February 10, 2018, 12:32:40 PM »
Not usually - it all depends on what signal your BOB is looking for - some go to 0v on the BOB, some goto +5v on the BOB etc
Is there no connection for "inputs common" on the BOB?
« Reply #26 on: February 10, 2018, 12:40:03 PM »
I have UP on input 1, DOWN on input 2, ARC on input 3, and COM on input 7?
« Reply #27 on: February 10, 2018, 12:42:11 PM »
It’s a gecko g540 board
Offline Davek0974
  •  2,606 2,606
« Reply #28 on: February 10, 2018, 12:54:25 PM »
Looks like you want pin12 NOT 7 as com.
« Reply #29 on: February 10, 2018, 01:08:12 PM »
I have it all wired up as said, what should my setting be in Mach?
